  1. Hello,
    I have just ripped a DVD disk of one of the series that contains 3 episodes. I found that a set of VOBs contained all three episodes as one video so I copied these VOBs including IFO and BUP files. All together, the whole video takes ~ 2 hours and 40 mins.
    I tried to extract subtitles as well but two programs I used for subtitles extracts (MeGUI's VosSubber and VSRip of MFC) only extract subtitles for the first episod. I found that IFO reports that the film is only ~ 55 mins long.
    What could go wrong? DO you think I can still extract these subtitles? VLC can find and play them well.
    Thanks.
    PS> The title says IFO files but it supposed to be an IFO file!!! Sorry about that.
  2. With VSRip you're presented with a choise of which pgc to use. Just select 2 & 3.
Name:	Screenshot - 11_16_2015 , 2_24_48 PM.png
  3. Brilliant! It worked. I've just had to add delay to each subtitle file as they were appearing at the same time but I've worked that out
    Just a question if that's ok. What is exactly the PGC?
    Thanks!
